Freelancer needed to help with setting up elements and testing
Hi All,
I am looking for a freelancer with Bubble experience to help configure specific elements that has lots of fields (over 400) that passes the data to a third party and review the outputs to make sure its passing all the correct data.
The task would require the freelancer to get an understanding of our data types and how I’ve setup workflows to save data into the different data types and then help setup the workflow via the plugin we have to pass that data to the third party printing service.
The freelancer should be able to work in EST time and come to daily morning standups.
Thanks
JD
@jdeleon1 we can help. Sending you a PM
