GroupFocus width same as the reference group?
Hello guys,
I’ve been trying to find a solution for this one over the forum but I couldn’t find.
From the screenshot, I want to make the width of GroupFocus the same as the width of the field which is leading to a dropdown (GroupFocus):
Is there any way to make this possible? So literally the width of GroupFocus same as field “Main traffic source”. The “Main traffic source” field does not have a fixed width.
Any help is appreciated.
Best,
TP
I had the exact same query which I posted here → Group Focus max width within reusable element
Unfortunately I did not receive any answers :frowning:
Hey @espptyltd and @petrovic.teodor ,
i think the solution must be simple for this that give the same style(height, width, padding, etc) to focus group as the other group.
what’s the issue here!!?
This requires a bit of CSS:
just for a try i created a dropdown and a focus group. gave fixed width to both 90% and the same alignment.
and its working properly.
It’s not the solution because the input field is responsive (does not have fixed width), therefore a GroupFocus should be responsive relative to the input field.
Thank you @ladd0393 , I will take a look at this video. By title, it seems it’s exactly solving this problem.
