Hello Everyone,
I would like to add a dropdown list to the coffee shop creation part of the lesson so users can add more information about the coffee shop. So they would select either Starbucks, Dunkin Donuts, or Local Shop as part of the dropdown menu.
Then I would like check boxes on the map portion which allow users to select for one of these three options to display only those locations on the map, e.g they check the Dunkin Donuts box and only DD locations show up on the map.
I can’t seem to be able to like the dropdown selection to the check box, could someone please provide some input here?
Here is an example of what it might look like
https://coffeeanddescription.bubbleapps.io/version-test?debug_mode=true
Thank you, Chris
