Help: Backend worflows
Hey all,
I’m setting up a backend workflow which is supposed to reset every user’s ‘API count’ data field and make it equal to their plan’s ‘API limit.’
My first question is, when making changes to a thing, should I use the ‘this user’ , ‘current workflow user’ or ‘current user’ options if I want it to effect every user under that plan?
Secondly, what should my backend workflow look like (parameters and steps) in order for it to refresh the ‘API count’ for every user?
It’s supposed to refresh on the next plan’s refresh date - usually a month or a year apart depending on the plan.
I’ve been trying to figure out this feature for almost 2 weeks now. Any help is greatly appreciated.
Thanks,
Mohamad
