Help: Click an icon and select dropdown option
Hello! Can someone help me!? Is it possible to click on an icon and with that action select an option automatically from a dropdown? Thanks!!! :slight_smile:
Hi there, @base… if I understand your post correctly, one way to go about doing what you have described is to use a custom state. You can set the default value of the dropdown to a custom state that has a type of whatever it is that is producing the options in the dropdown (for example, an option set). Then, when the icon is clicked, you set the custom state to one of the dropdown options, and that option will automatically be selected in the dropdown.
Hope this helps.
Best…
Mike
