Hello Guys,
I am facing this error that i can seem to trace! Can anyone help
https://iwp3.bubbleapps.io/version-test/best-parts-offer/1474898379724x632019627915345900
Hello Guys,
Search the browser source pages for image_name.png you have an incorrect link somewhere, once you track down the element that is calling it, it might help you solve the problem.
Go it. It was caused by a group that had a dynamic background image. when sample data is shown in the testing environment it throws an error.
Makes sense. Not a problem to be honest
Yes true. Was trying to use the image element instead but its missing these set of options compared to the group element.
Was wondering how easy can it be to add them to the image element?
It doesn’t make sense to add that to the image element, because the image element has a size and the image follows that size.
