Our app allows enterprise customers to sign in via Okta, but the problem is that we rely on the API Connector while doesn’t allow for dynamic data. I’m looking for a developer to help me convert our set up in the API connector to a plugin so we can utilize dynamic data across our various sub-apps.
More information:
Almost all of our customers use Okta for their single sign-on. We use Bubble’s sub-app feature to give each customer it’s own dedicated URL and database, but the problem is that any time I push from the main app to sub-apps, the values in the API connector get overwritten. This means that to use the sub-app feature, I’d have to reinitialize the call on the sub-app.
I originally followed these instructions that I found on the forum to build the Okta SSO via the API connector.
I was looking through the forum earlier today and found this thread where you can make a call that you use in the API connector into a plugin. I think if we were able to convert the current Okta SSO (done via the API connector) to a plugin, we’d be able to go back to using the sub-app feature and I wouldn’t have to worry about all of the inconsistencies between applications. According to Bubble, pushing to sub-apps doesn’t overwrite the plugin keys for the sub-apps.
Anyone available to help with this? Paid job of course!
