I’m struggling to properly link pages.
I need to use the link element for SEO purposes (crawlers don’t see the workflow-based navigation).
However: links only support text, I need to be able to ‘wrap’ whole groups. Besides that I need to be able to trigger workflows based on link-click.
Do you know of a plugin that supports these needs, or an other way to achieve this?
I don’t know how you designed the stuff right now but maybe you could combine both things ? Normal action for better ux and links somewhere on the page for the SEO.
I haven’t tested something like that - but that’s the first thing that came up to my mind after reading your question.
Thanks! Yes that is kinda what I do now. But it is very error-prone, both from a use-perspective as from maintenance (need to double all workflows, or define custom-workflows for each).
Example of biggest drawback:
I have a group with a navigation-workflow (plus other actions). Within that group is a link element for SEO. When someone clicks the link however, all the workflows for the group-click aren’t executed.
I could overcome this by making the link very small, but that is way to hacky for my liking. Plus Search engines really don’t like it.
Ok I think I stumbled upon the best solution . Still hacky, but better than before.
It is not possible to trigger a workflow based on a click on a link-element. It is however possible to first create a butten. Create the workflow. Then change the element to a link (using the right-click menu on the button element).
I then position the link element above the rest of the elements and set it to 100% width and height. Covering the whole card.
This way I get the link functionality & the option to trigger a workflow.
