Help Needed: Slug Generation Issue on Mobile vs. Desktop
Hi everyone,
I’m currently facing a perplexing issue with my Bubble app and would greatly appreciate any insights or suggestions from the community.
Problem Description:
My app is designed to generate a unique slug for each uploaded image, which is then used to create shareable links. This functionality works flawlessly on desktop devices; the slug is generated, and the resulting URL is complete and functions as expected. However, when the same process is initiated on a mobile device, the slug fails to generate, resulting in an incomplete URL.
Details:
  1. Workflow Overview:
  • The image is uploaded.
  • A session ID is generated and stored.
  • A slug is created based on the session ID.
  • The final URL is constructed using the generated slug.
  • This URL is then shared via the Web Share API.
  1. Current State Setup:
  • Custom states are used to store dynamic data.
  • The workflow includes steps to ensure the custom state is set with the session ID and the slug.
  1. JavaScript Integration:
  • A JavaScript snippet is used to construct the URL and invoke the Web Share API.
Issues Encountered:
  • On Desktop: Everything works perfectly; the slug is generated, and the URL is complete.
  • On Mobile: The slug does not generate, leading to an incomplete URL (/response/ without the slug).
Troubleshooting Steps Taken:
  • Verified the workflow steps and custom state settings.
  • Ensured that there are no conditional settings or responsive settings affecting the slug generation.
  • Tried different approaches, including setting a hidden text element and directly referencing the session ID instead of the slug.
Request for Assistance: I’m reaching out to the community to seek your advice on the following:
  1. Has anyone encountered a similar issue with slug generation discrepancies between mobile and desktop?
  2. Are there any specific settings or workflows that might cause such behavior on mobile devices?
  3. Any alternative approaches to ensure a unique identifier is generated and included in the shareable link for mobile users?
Thank you in advance for your help!
