Help on responsive navigation bar
How would I make a responsive navigation bar? Like if the screen width reaches 50%, I want the group links to turn into a single slidable navigation bar.
Hey there @sonik :wave:
Welcome to the Bubble community! You can do this in the responsive tab. There is a hide feature at a certain width that you can use on those elements. Then display the slide menu at the same time you hide the other ones. Let me know if you can’t find the checkbox and tomorrow I can take a screenshot for you when I get to my computer. :blush:
Hope that helps! :blush:
@j805 www.NoCodeMinute.com
  • One-on-One Tutoring
  • eLearning Hub
  • Video Tutorials
  • No-Code Classes
