help saving and adding data
Good afternoon, I would like help with the following. I have this “form” where I show a list with employees with a daily salary as shown. In the following table there is a repeated group that shows some monkeys with a checkbox, that data comes from a table called extra bonuses
I would like it if when you click on an amount it would be added and displayed as part of the total, and if you uncheck it subtract that amount. Thank you for your time. good night
