Help showing inner group predictions inside bet card (repeating group setup)
I’m building a football prediction MVP in Bubble and I’ve run into a problem with how to display predictions inside a bet card
Setup so far:
  • I have a parent group (“GameSlip” / bet card) that shows details like:
    • Stake
    • Ticket type (single/multiple)
  • Inside the bet card, I want to display a list of predictions for that bet (e.g. match, market, user’s pick).
The issue
  • The parent group (GameSlip) is displaying correctly (stake, multiple).
  • But the inner repeating group for predictions is empty in preview — nothing shows up.
  • I’m not sure if I’ve linked the data source correctly from the bet card → its list of predictions.
My question:
  • How should I structure the data type / relationships so each GameSlip bet card can show its list of predictions?
  • Is it better to:
    1. Store predictions as a list inside the GameSlip data type, OR
    2. Create a separate “Prediction” data type that links back to the GameSlip?
  • Any examples of setting the Data Source for the inner repeating group so it correctly pulls the predictions for the current bet card?
Thanks in advance! :folded_hands:
