Help Us Contribute to the Future of Bubble Mobile Plugins
I appreciate your feedback. We’ve updated the title and removed the word ‘dominate’ as I do agree with your point. Regarding the opportunity to build plugins for the marketplace, we will keep the pricing the same for any plugin priced under $20. That’s a guarantee. :+1:
A plugin to be able to store some data in the device would be usefull.
thx
Use our local storage plugin
Uploadcare plugin now supports adding from the camera and also documents.
Hey can you create a better input box? The features it needs are:
Dynamic width, so that you can prefix it with a $ (look at photos in stripe app for example)
Wrap text into multi-line - multiple forum posts on this - Multiline input text alignment bug on mobile - #5 by harun_kaldi
Also do you have any idea when SDK plugin support will be available? Is it even possible?
We have a custom input plugin that does support prefixes
Link: Advanced Input Bubble Mobile Plugin | Bubble
I didn’t read through the entire thread, so apologies if this has been mentioned, but it would be nice to have a plugin that allows an image popup with touch zoom functionality and includes share and save to device buttons and a close button.
Sticky horizontal groups
Image cropper is a must ;_;
On our roadmap, we’ll keep you posted. Waiting for access to custom sdk’s.
Okok, last one:
Websocket support for a chat app would be killer :slight_smile:
@nocodeventure can add a “done” button to the keyboard to hide it?
right now there’s no way to hide the kayboard on multi-line input or number type single line input. users get stuck w/ keyboard open and can’t advance in app. Huge problem/
Do you have specific examples of what you’re looking for? I’m not aware of a “done” button.
Yes. See below
Any Possibilities you could ad custom map skin on the mapbox plugin?
best regards,
is there a rich text editor available?
Hi Liam,
We don’t have a rich text editor atm, i’ll see if we can add one soon.
Hi Rikard,
Yes we can, what skin would you like?
Just a custom one I create in mapbox!
