Help using Bing api
Hi everyone. I’m trying to use the bing api to search but I want to filter it by ending.
so .gov and .edu sites would be first and others would come last. Is this possible?
You could have two separate repeating groups styled the same, one above the other. The top one is only filtered to show .gov and .edu and the bottom filters out those two to show everything else.
You can also have visibility and group collapse conditions for both RGs so that if one of them doesn’t have any results, it gets hidden/collapse and you just see one without any white spaces.
Might be easier than figuring out a custom sort order for something that wouldn’t follow alpha order anyway because there are web extensions that come before and after .gov and .edu.
Gaby | Private coaching, courses, and tons of free resources
Become a VIP Member for immediate access to 100+ lessons, videos, webinars, and more
