Help with a CAD/MDT
I have bought a template on bubble and I cant figure out how to change the access password that he made
If its a stolen CAD, You will need to go to “Data” (Should be on the left side panel) Then once there, Click App Data. Now there should be a row called “cadInfos” The access password should be there.
Thank you
I have changed it but it still dosent work
