hi, i need some help with my api call, i got an error that i don’t understand.
Here is my call →
Here the error →
it say missing required property fieldData but i writed it in my body …
Here is my call →
Here the error →
Hey @vbouet,
while I did not look at Webflows docs, common things to try would be one of the following or both:
Content-Type
as the key & application/json
as the value.<main-image>
and adding the URL into the dynamic field that will show after you’ve added this.Lmk if this works for you.
Please add a link to API doc. If the content-type expected is really application/json, you should follow what @jukoen said.
here → Create Collection Item
ok boys my bad i writed “Content_Type” instead of “Content-Type”…
pls somebody kill me !
