Help with Constraining Addresses
I’d like to do a calculation on the round trip miles for an address selected from a dropdown to calculate the expense amount.
I’m running into trouble with the address constraint.
I need to find the address that was chosen from the dropdown in my data and then get its round trip miles.
I was able to get a result using :first item thinking that my constraint would yield a list with one item and then the first item is the only item.
But the result was incorrect leading me to think that my constraint isn’t working.
Any suggestions?
Your non-working version seems restrictive. It may not be finding any results or it could be a data type issue. What step calculates the round trip miles?
Let me know if you want some help with it: https://calendly.com/slickrock-15/15min
