Help with dependent drop down
Hi guys, newbie here.
I created 2 dropdowns one for country and the other one is a dependent drop down of cities in the country.
It works well but the problem , is that the second drop down sometime caches the previous answer
Any help ?
You can use reset relevant inputs to clear the dropdowns
and how do i do that exactly ?
In the workflow, add “Reset relevant Inputs” at the end
