Help with filter in a repeater group
I have a table called SCHOOL and inside it I have a capo called SERIES that pulls a list of SERIES and another field called STUDENTS that pulls a list of STUDENTS.
I need to filter the students of this school by grade.
I can list the students at the school without using Search for.
But when I use Search for, all registered students appear.
If you’re doing a search, then add constraint for ‘school’ and ‘grade’ when doing the search.
If you’re accessing the students by referring to a list, then apply a filter to the list using :filtered. Then set a constraint for grade on the filter.
Thank you friend!
It helped a lot.
