Help with Percent of Total Calc
OK. This is probably incredibly simple, but I’m missing it. I want to calculate a percentage of a total A / (A+B). Problem is how do i add the parentheses with dynamic data? Thanks.Screen Shot 2020-10-09 at 1.00.03 PM
Bubble doesn’t follow standard order of operations in mathematics.
So you will need to break up your formula to make it work correctly. You could use a hidden input to calculate A+B, then reference that in your final calculation. “A / hidden input’s value”
