Help With Repeating Group and Constraints
Hi there,
Is there a way when using constraints to reference in the constraint the users you are searching for.
So in the image below with the second constraint, is it possible to where it says CLICK, add a datatype of the thing you are searching for.
I hope that makes sense. Any help would be hugely appreciated.
Yeah sure!
Just have an input called “miles input”
And where that [click] is put the “miles input’s value” and it should work!
