Help with user location (mobile)
Hello guys, I’m developing a mobile app with Bubble and I need to restric some options based on user location. For example, I have a combobox with some countries and states (usa/florida, usa/california, etc), and I need to figure out a way where only users phisically on those locations be able to select it, I mean, only if the user is phisically in Florida he can be able to select this option, for example.
What’s the best way to do it? Is there any plugin to help me with that if Bubble can’t do it natively?
Thank you so much!
Location with Google maps is basically built into Bubble.
https://manual.bubble.io/help-guides/working-with-data/working-with-location-data
If you are using a native app wrapper (eg Thunkable amongst others) you also often have access to the native mobile app location services. But this isn’t necessary as location is built into browsers now anyway.
Screenshot 2021-12-05 at 09.47.04
I’ll definitely give it a try, thank you so much!
