Hi guys... I need help!
I can not do deploy! The error appears in the screencast: https: //www.useloom.com/share/cf437460ebf811e6b8fde34d395e0c71
Does anyone know what should be done?
You have your map set up to display markers from a list of addresses in your database. It’s looking for the field that contains the address for each marker, and it looks like that field doesn’t exist in your User type yet. Add a geographic location field to your User type and enter address values for each User in order to display a marker for each of them on the map.
