Hiring for multi select filtering /uploading a variable product
Hi all,
I am building a marketplace for clothing, I’m really stucked on 2 points
  • I need help with multi-select filtering (ie : I need the user to be able to select among different colors, categories, size, if the delivery is free…).
  • I also need help allowing the user to set up a variable product with different size and color options and matching images (just like Spotify or Wordpress)
The visual part is already done, it’s just the programming left I guess.
Please tell me your price ?
I’m also opened for charity work :smiley:
I can help you with it, can you DM me you issue. I will not charge you. I will do it for free.
You can use dynamic name feild on the place of constrain. So your user can dynamically filter things.
Hello @graziellamk
multi-select filtering should show exact matches or any matches?
Can you please elaborate what you mean by variable product.
Hello , it should show the exact matches any time a filter is added to the list
Hello Graziella, I have developed a platform for micro-gigs on Bubble for this kind of request. You can ask for help with no-code development, or you can help other users with some micro-jobs. Take a look! :slight_smile:
https://nocodegigs.io/
