Lol , yep!
yikes… still cant get a group to scroll horizontally… is this smth that can only be fixed with code?
Yes, simple css for the x-overflow. Check got 3wschool for simple css like what’s needed. Add id to group and use the id in code via html element
I created a plugin for this, you just need to enter the ID of the parent group and activate it in the workflow when it is visible
You might be able to use a repeating group for this:
- Set the number of rows to fixed 1, and do not set a fixed number of columns (or set it to just 1).
- Set the datasource of the repeating group to a list of 1 element:
3_) Now add some content to the repeating group that is wider than the allowed width of the repeating group (I added a text field with a lot of text):
- When you run the app it should show the repeating group with a horizontal scrollbar:
Hope it helps!
thanks so much!!
nice! worked
Saved me from a huge rework effort. Thank you!
Just managed to get this to work. Great approach
