I’m writing a plugin that creates a dropdown menu, and it can be used multiple times on the page.
Now I want to add a class to each instance of the dropdown menu, but only if specific conditions are true.
Here is a trimmed down version of what I’m trying to achieve:
//This selects an input element from the page
instance.data.input = document.querySelector("#" + properties.input_id_box);
//Build the dropdown menu instance
instance.data.iti = (lots of code here - removed to make this post simpler)
//If input has the disabled attribute set, look inside this menu instance for the HTML element ".iti__flag-container" and add the class "bjg_disabled"
if ( $(instance.data.input).prop( "disabled" ) == true ) {
$(instance.data.iti).find(".iti__flag-container").addClass("bjg_disabled");
The if statement
returns true, but the class bjg_disabled
is not added to the dropdown menu.
Note: I am using instance.data.iti
inside the if statement because I only want the class added to dropdown menus with a corresponding instance.data.input
property of disabled
