How to calculate a ratio between two agregates inside a Group By?
I’m trying to create a grouped dataset in Bubble where I group data by age and want to display a ratio of two aggregates on the chart.
My goal is to visualize this ratio on a chart — X-axis = AgeGroup, Y-axis = (Count / sum of GetSlot).
How to Generate a list of results of this two aggregates:
(CountAgeGroup 1 / SumAgeGroup1, CountAgeGroup2 / SumAgeGroup2, … ,Count AgeGroupN/ Sum AgeGroupN )
When I use it in the chat I can select only one of them
You can use the :formatted as text expression. Inside the formatter, do the math you need
