How to Cross-reference Two Databases?
I have a text element that displays a user’s token balance (stored in Payments DB) using the following logic:
*Search for Payments:first item’s Tokens *
(Condition Created by = Current user)
I want to add free trial functionality, these users would not be included in the Payments DB (entries created by the stripe subscription workflow & maintained by webhook) and although I could add them, and my webhook logic is robust enough to avoid this generating errors when the webhook pushes an update for the same email, I would rather use the User DB, and keep the Payments DB just for paying customer records as intended.
To do this I would need to be able to cross-reference the Payments and Users databases. Eg, to retrieve a users token balance, the logic would need to be:
If Created By = Current User is not found in Payments DB > Text = User DB Trial Tokens
else Text = Current Users Payments DB Tokens
I would also need to do a similar thing in a few other workflows, can anybody tell me if this is possible and if so, how to go about it?
Hi there, @blogshackltd… if I understand your post correctly, you could add a condition to the text element that says when Search for Payments:count is 0 (constraint Created by = Current User), change the text to Current User's Trial Tokens.
Hope this helps.
Best…
Mike
Thanks mikeloc, yep that did it :slight_smile:
