How to display current and next item from a Repeating Group? Need help
Hey Bubble Community!
I’m trying to build something similar to a Tinder-style swipe interface where one item is shown in the front, and the next item is preloaded right behind it.
Here’s what I have in mind:
  • I’ve got a hidden repeating group that holds the full list of items.
  • On top of that, I want to show a “Current” item (the one that’s currently visible/active).
  • Behind it, I’d like to show the “Next” item (the item that comes right after the current one in the list), almost like a preview or transition effect.
I’m a bit stuck on how to structure this best:
  • Should I use 3 repeating groups, or would it make more sense to have 1 repeating group (hidden) and just 2 Groups pulling from that list?
  • I’ve figured out the visual layout, animations, and swipe logic – but I can’t quite wrap my head around the data source logic for showing item #current index and item #current index + 1 properly in the two Groups.
Any tips, ideas, or examples would be hugely appreciated!
Thanks :raising_hands:
@adamhholmes if you have a minute and might be able to help me with this one? :pray:
I’d do it this way
That’s basically exactly how I’d do it. You’ve pretty much got the correct logic in your post and diagram.
Which part of you having trouble with?
Thank you Adam for the quick response! Not sure how to get the active index #? What i did now is i have a state called “index#” and default is 1, then is i go + then i do +1 if i go back -1 and that seems to work but not sure how “stable” that is?
Yeah, that’s exactly how it’s done.
