How to duplicate and move elements around inside a container?
Complete newbie here, Watching a beginner tutorial. I’m trying to duplicate an element inside a container and also move it around. Im on mac and the tutorial seems to be using window which they can duplicate by holding “ctrl-drag” and moving an element around by shift and dragging? I know its probably an easy fix but elements seem to be stuck in place on my screen. I’m on fixed btw
cmd + d
To duplicate it, you could either:
  1. Copy the element by right clicking on it and clicking copy and pasting it
  2. Using cmd + d
It probably has a fixed container since you can’t drag elements if you use row or column. Alight to parent can be dragged but it’ll stick to a specific portion / space
