How to evaluate conditional on Current data
I have a database thing called LineItem.
LineItem has a yes/no field called Taxable
The goal is to only calculate the tax on each LineItem if the field is yes and to set the TaxAmount to 0 if the field is no.
Here is a workflow that calculates the tax for a list of LineItems.
Note that the tax rate is set on the parent(Invoice) and then all the LineItem for that Invoice are found through a search.
Any help/pointers, would be greatly appreaciated.
This Item’s Taxable is yes:formatted as text:converted to number
When yes, = tax rate * total
When no, blank/0
Solve the problem by creating a standalone API Workflow that accepts a LineItem, then search all LineItems, and then schedules API WF on a list with the search result. With this I can evaluate the boolean on each item
I promise the solution above is the right solution as yours is adding unnecessary complexity and obscene WUs but glad you solved it anyway…
