How to fire a sound effect for all clicks that generate workflow or action
Is there an easy way to create a workflow that generates a sound effect whenever a click takes place on the app? I have the audio player and play-action figured out I just can’t solve how I would go about creating the workflow.
One option would be to create an action for each button and link but there should be a way to get it to apply to all links and buttons with one workflow? Or is that impossible?
Appreciate any advice:)
