How to fix Workspace Button Animation Issues
Reaching out to see if anyone else has thoughts on why the Workspace doesn’t run through the same steps as it did the first time around exactly as before. Have any ideas? Here’s what happens…
  1. On a previous frame you click “Create Contract” which starts the Workspace process. The pics/text/buttons start animating in with a FadeIn
  1. The ends up looking like this
  2. But when you click on “Go Back” and then “Create Contract” again (say you wanted to change a few items and re-create the contract) It reveals everything and then does the FadeIn animation.
Here’s my Workspace if that helps…
So… logically I’m thinking that there is some action that I’m missing that tells the Workspace to start over (like a reset all parameters?). What do you think?
