How to get a sub-list using info from 2 separate lists?
I have 2 lists:
  1. List of texts
  2. List of yes/no
I want to extract out a sub-list of the texts from the 1st list, IF the corresponding cell in the 2nd list is a “yes”.
Is there any way to do it in a single expression? (as this is supposed to be in a condition)
Hi there, @jayy… you are probably going to need to provide more information in order for someone to be able to help. For example, what do your data types look like? How are the two lists related? What do you mean by get/extract out a sub-list? Get/extract it out from where and do what with the resulting list?
Best…
Mike
