How to highlight for a few seconds?
Hi all, after a user completes a form (which is on a popup) I would like then to go to another page and for a specific group to fade in yellow for a second and then fade out.
I can’t think if this is done with ‘on page load’ workflows or if there’s another way. One issue I had was how to implement a fade?
Set a custom state, and use conditions on the group to make it yellow…
On load, schedule a custom event after a certain amount of time to change the custom state value, and set a transition on the element to make it fade.
Fade Group (bubbleapps.io)
Absolute legend. I see now that it is the Background style transition “Ease” which gives it the fade effect. Thank you so much.
