How to reposition and resize images without repeating?
hello friends, does anyone know how I can rearrange the photos after being published using the repeater? is there also the possibility of resizing the image, after being published, to four or 8 squares to highlight it in the profile? thanks!
Exemple of changing position of image after published in feed (using the finger to move it)
Example of a featured image in 4 squares (the image on the side moves to adapt to the new layout)
Hey @rodrigo-salomao
This sounds like a job to be solved with the Draggable plugin by Bubble. It helps you achieve that drag-and-drop functionality to re-arrange the images.
And for resizing the image, the classic :processed by imgix, which is found at the end of a dynamic expression on an image-type element should allow you to set a standard for which you want the image to be resized.
thanks a lot buddy!
But How can I use drag and drop in practice? I tested the plugin but I couldn’t make the photo stay fixed right after the other as soon as I dragged it to the side.
As for resizing the photo, I already knew about processed by imgix, but I didn’t find the function where I can resize the photo in the feed using two fingers, as if I were zooming in, you know?
