How To Split A Number In 2 Parts?
I am trying to add hours and minutes to a date…
I have a timezone offset arriving as a number via the bubble API.
How do I split off the last 2 characters from the number received?
Example, “-0700” should become -07 (hours) and 00 (minutes)
Or “+0300” should become +03 (hours) and 00 (minutes)
Bump on this…
How can this be done inside Bubble?
Can anyone help?
Thanks
@JustinC extract with regex. For last 2 characters, use pattern ..$
I thought this may have been the answer, but I don’t see that option:
The -0700 is being received via api as a number so that i can add the hours and minutes to a date to convert the date to UTC. But I need to seperate the Hours (-07) from minutes (00).
@JustinC Above method is for text which makes it easier to deal with extracting characters. If you can return as date/time then you can do calculations like extract ‘hour’ and ‘minute’.
You are receiving a text (string) and can split and parse this text as you want using REGEX, however you need to make the resulting text type into a number type so it may be used in a calculation. Unfortunately, bubble doesn’t do this as standard and so there are a few ‘type changing’ plugins that can do this.
Here is your regex for grabbing the first three characters
and the last 2
https://cl.ly/fce66e635452/Image%202019-08-14%20at%205.27.36%20PM.png
One plugin to convert text to number
