Hi
My app provides audios to users, similar to Spotify.
For a better understanding of how users interact with the audios, I’d like to store more data like:
- how many times, by whom and when an audio has been listened to.
Is it preferable to add a dedicated data type (e.g. Audio_Played) just for this use and record each event as a new entry, or should I add fields in data type “Audio”?
Hi Paulo,
I would create a new datatype to track usage. (but see note about using Google Analytics and alternatives as a different approach)
Lots of reasons including
- simplify privacy rules - new datatype will have different readability requirements to your Audio tracks
- updates to this data type can be done from a backend workflow - move the load off the front end
- you can export your usage data from a single data type (ie from the editor)
- you can do maintenance on this data type eg delete usage history older than 1 year
- you could open up this data type with the Data API and plugin some 3rd party tools to read and analyse this data
Another option - if you were very worried about WU, you could unload this “tracking” and use Google Analytics, Plausible … (many many options - which is best is a whole other conversation) and push metrics into a 3rd party and combine it with other web behavioural tracking.
What I’d probably do - is initially do both - a datatype and something like Google analytics. With a view to ultimately getting rid of the Datatype once the WU usage cost vs 3rd party complexity cost equation made sense.
OK. All your reasons make it pretty obvious…
About using Google Analytics or Plausible:
How would you track which audios a specific user listened to?
e.g. Plausible’s plugin action just let’s you define a trigger goal. You can’t really send any additional data.
In GA you would add a “dimension” - which is an attribute of your data - eg if what happened in your app is ;
Bob listened to “Taylor Swift” 2 times.
The event is “listened”
The attribute is “Taylor Swift”
The metric is 2
https://support.google.com/analytics/answer/1033861?hl=en#
You can do this in a plugin - many available - I obviously prefer my plugin
