I help help with Tokens
Please help me amazing people of Bubble
Ok, I was able to get the unique token return by the first API call to get permission to create a user (customer). Each user has a unique code or token number.
But how do I make another call with A unique identifier returned by the /start API call that is passed with most subsequent API calls to tie them all together? Below is a picture with an example.
Thank you in advance.
It may help to show us the API docs.
But if it is in a Workflow step, then you can use the return from that API in a subsequent step.
Or store in on the database ?
Hi Nigel, Thank you for your reply.
What I need to do is to save that specific token return by the API to use with another API CALL.
Thank you
