I need a confirmation box for actions
I need a confirmation box for actions such as deleting or registering a record that returns Ok or Yes or No.
How to do it or do you know any plugin?
Can you help me ?
No plugins, when they click the button just show a popup, then the popup has a “Yes” button doing the actual workflow (and hiding the popup) and a “no” button that just hides the popup.
Yer. woh
Obrigado!
