I need help for tep shelf calendar
hi , I want to add a text on the calendar cell
. The logic behind the workflow is simple, When a click the button edit me ont he popup I create three things a name, a date and a type :Capture .
What i want to do is to show the text that matches the date on the cell I have done it(
But i do have a problem, the text on the calendar cell has the value of one input in the popup(
so when I reset the input it logically makes the text disappear. How can i make text appear to solve the problem?
i find the solution ,sorry it was simple and i have complicated it to much
