I need help making a Forum Page
Hello, please DM ( Aspect#4716 ) on discord if you can help me or give me tip to making a Forum page on my bubble.io site. Thanks
You can try my template. I have a forum template you can buy or take a look at for ideas. Hope that helps! :blush:
Halo .
What’s the name of your template and where can I find it as I also want to build a forum.
Here is the direct link to the template. https://bubble.io/template/simple-fast-loading-forum-1554006263397x274387721704701950
You can take a look at the preview to see it in action.
Also, here is the original post about it [Template] 💎 Simple Fast Loading Forum
Hello, unfortunately thats out of my budget. Would you be able to give me a one time deal?
Well, you can use Discourse. It’s open source. https://github.com/discourse/discourse
Hope that was helpful. :blush:
Hi there,
We have a tutorial on exactly how to build a forum at nocodify.com, check it out!
