I need help on fixing this
Hello I’m trying to get user’s address by using calculate CoordToAddress function. Using the Geolocation(GPS) Tracker plugin, I successfully got user’s latitude and longitude. But when I plugin those values into the CoordToAddress function I’m keep getting empty. I have no idea why it doesn’t work. (The reference images are down below). The function worked properly when I used previously. I sincerely needs your help. Thank you.
Are data types same? I mean is one expecting number while you are providing string or something like that?
In second step are you using step 1’s result to make sure step 2 runs after step 1?
Have you printed the latitude, longitude values that you got from GPSTracker to confirm they are coming fine?
