I need help with dropdown boxes
So i have a dropdown box with three static options. I can’t figure out how to make a workflow that reveals a hidden group for each of the three options. Basically each option is a different type of user and when selected, a hidden group will appear to show them a user specific sign up form. Can anyone help me with this?
Create an options set and call it “type of user” and add the three user types
In your dropdown select dynamic
Choose “type of user”
Create an options set on your page called “type of user” of type … options set “type of user”
In each group place a conditional that says “when current page user type is …” make this group visible
Hope this helps! :+1:t2:
