Hello I need Help!
Can I create a certificate with PDF conjurer ?
Some Rectangle Like this ?
Try using a rectangle as an image as a background
Yes, and I can say that because I used PDF Conjurer to build a certificate emission control app for the college I work at ^^
Iād make a rectangle image (in Paint or PowerPoint or whatever you want to use), and set it as a background image.
You will just need to adjust it to fit as needed in the page.
You can even add watermarks if you need to.
