IF statements help
Hello everyone,
Wondering if there is a way to write IF statements in bubble. For example…
IF (boolean is_Valid is false) display “This value is false”
ELSE display “This value is true”
I am surprised that this is not an obvious function in bubble (Maybe it is).
thank you
You can use conditionals to do that. You can set the initial value to say it is true, when it is true then do a conditional when it is false then you change the text to say it is false.
Hope this helps you.
Lester
