Forum Documentation Showcase Pricing Learn more
If/then when setting data values
Has anyone found a good way to do if/then type logic when setting values?
For example, I want to remove a text value if a check box is unchecked.
You can put the input in a group and then reset the group when the box’s value is changed.
I’m sorry, I’m not following. Are you saying make a group for each check box and populate it with data if the check box is checked?
A group for each box is probably the way to go, if you want to reset each slider independently, yes. I wonder if it’s necessary UX-wise, but it’s up to you.
