Input keeps getting cleared for color picker and multiline input
Hi all
I have built a bit further on the website we built alongside with Greg in the “Get started with Bubble” YouTube tutorial.
As in the company page made in the tutorial there is a part where the user can submit name, company description and so on. There is also a function for the user to later on edit, and the inputs that the user should edit is still visible in the input fields.
I have added a lot of extra fields and It works great for most of the extra fields I have added. I want my users to be able to select a color from the color picker plugin called “Air Color Picker”. It actually works great for the user to pick the color. But when the user goes into the edit section, then the color is no longer in the input. This means that if the user change some other fields but not the color, then there is a standard color code chosen. It also happens with a multiline input.
I have a workflow for both creating and editing and it works great for all the other inputs. What to do?
If some of you want to check, then here is a view-able link Alex-72384 | Bubble Editor It is in the “Company” settings
All help are much appreciated!
