Inspect problem
Hello babblers
Am I the only one having problems with the inspect?
Check your zoom level or refresh your page, I can see the menu alright. Yesterday I was having weird problems with certain elements hiding behind others like that too. Hope that helps. :blush:
Thanks but
Zoom - no
Refresh - no
I went to another project and everything works fine there. :thinking:
So weird :man_shrugging:
I’ll bet you are using the new expression composer in the project where it isn’t working. Turn that feature off, and it should work again.
I hope they don’t make the expression builder an update anytime soon. It has so many issues. :man_facepalming:
So. Thank you. It worked
