Intersect with and split by:
How to add character (#) in the instersected items?
example423515
example244141
How to add “#” before each word? Comma is fine to have, if possible to remove as well, but not priority.
Use format as text on the list.
(Although I can’t work out what you’re trying to do here…)
Would like to have the three words (communication, managment, innovation) to be: #communication #management #innovation
example2411512
:format as text :thinking:
yeah…
assuming the keywords are just texts, just use: format as text…
Content per list item: #This text
Delimiter: space
Yes. It works! Thanks @adamhholmes! #grateful
